Help identifying an old wah shell
Started by cordovaplata, May 01, 2015, 06:36:41 PM
cordovaplata
I received this dead wah shell from a friend, I refurbushed just the switch and the inductor, the shell is missing the lid. I searched on the internet for pictures of this shell with no results. Any ideas what this might be?
P.D. The wah was black  ;)
Pictures:
Samuel Córdova
smallbearelec
It looks like a Crybaby. If you can find one in a shop, hold yours up against the bottom to see if the plate is the same size and holes are in the same place. If so, you need a standard bottom plate:
http://smallbear-electronics.mybigcommerce.com/bottom-plate-for-expression-pedal-shell/
http://smallbear-electronics.mybigcommerce.com/bottom-plate-for-the-crybaby/
Regards
SD
joegagan
#2
That is a new one on me.  Internally they seem to have cloned a post 89 dunlop cb. The cheap jacks and front silkscreened plate have a certain asian flair. But that art deco inspired exterior is its own thing isn't it?
cordovaplata
Right. Also, the inductor looks like something I've never seen before. What it is giving me a hard time identifying is the front plate, most wahs have plastic jacks at the sides!
Samuel Córdova
i have the volume pedal version of this...
its a...
unfortunately i removed/replaced the rubber pad with its name on....and can't remember what it was..
got it...my vol pedal is a ''DENIO VP''  8)
not the same size as a dunlop...a bit broader, same length-ish though..
same enclosure as
http://www.effectsdatabase.com/model/dixon/cbwahwah#
anotherjim
The inductor is on a standard "blank" bobbin. They are usually wound to suit. I think my old Vox fuzz-wah had that type, but it's long gone - and that ain't no Vox shell.
Is there any ID on the copper side of the pcb?
I think it's a Denio, going by a volume pedal I found that looks like Rob's...
http://www.pksmusic.com.au/showProduct/Sold+Items/Effect+Pedals+Sold/DVP/Denio+Volume+pedal
anotherjim
cordovaplata
Magnificent work! :D It looks like I need to learn more about wah history :/
I had the PCB and did the schem, it was a regular wah circuit, nothing fancy.
Unfortunately, I trew the PCB away since it was heavily cracked and the copper traces were corroded as well.
Samuel Córdova
