i think, i did spin fv-1 decompiler / disassembler
Started by gena_p1, May 19, 2015, 06:33:30 AM
taudio
Maybe give this a try instead?
https://github.com/ndf-zz/disfv1
We used it in our fv1_programmer (see https://pypi.org/project/fv1-programmer/) and it works well.
Quote from: ReedusPeem on December 05, 2023, 11:34:36 PMLink seems like it's down again. Has it been moved?
Cybercow
Quote from: gena_p1 on May 19, 2015, 06:33:30 AMOnce source files of reverb project were overwritten by mistake, so it was only one way to return back sources - to make decompiler and read the eeprom.
it's platform independend, cause i hate to compile anything on windows.
http://s.shift-line.com/decompiler/index.php
seems, it works fine with .bin and some .hex files, but need deeper testing, you may use it as is.
The site is down again. Will it be back up soon?
Cybercow (moo)
Don't let your talent take you where your character cannot keep you.
DrAlx
I use asfv1 as assembler, and disfv1 as disassembler.  They are both python programs.  Available from here...
Cybercow
Quote from: DrAlx on January 26, 2024, 05:56:58 PMI use asfv1 as assembler, and disfv1 as disassembler.  They are both python programs.  Available from here...
Saw that in the earlier comments. Thanks. And even tho I run both Mac & PC, I'm shit with command-line tools like that.
Cybercow (moo)
gena_p1
No, it still at my home file server, sharing 2Gb of RAM (windows 7 x32 limitation) with everything.
