unnamed fuzz
Started by Maroslav, May 24, 2015, 02:59:31 PM
Maroslav
Hi guys! I'm from Poland and I'm new Here
Last weekend I've decided to build X FUZZ.
After hours of tweaking I ended up with this:
Can someone verify this layout?
stonerbox
THE WIZARD!  ;)
The fuzz sounds great man, gonna have to build one. Cheers!
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
Puguglybonehead
Nice fuzz! Will have to try this one myself. Where did you find the AC121s?
Cozybuilder
Your Vero layout looks fine. I built this one awhile ago, its a good one.
Maroslav
Thanks, man, I really appreciate it.
I found AC121's in my Dad's electronics stuff
Q1 hfe is 325 and leakage is 0,4mA
Q2 hfe is 300 and leakage is 0,5mA
I'm confused about how this sounds that good with that leakage  :icon_confused:
DDD
Impressive sound!
Well Maroslav, is it possible to make one more soundclip with Si trannies just instead of both Ge ones? (No any more changes)
There's a solderless bbd on the picture, so it seems not to take too much time (?)
monksanto
Maroslav
I can try MPSA14 if you want.
MP20A should work, but my AC121's are from VII Hfe group, so they should have Hfe from 125 to 250
Gus
Reminds me of the MinuteMan fuzz posted in 2011
DDD
#9
Hi Maroslav,
MPSA14 are Darlingtons, so they are not "typical" here.
Something like BC556...560 are to be the best choice for that purpose.
Thank you in advance.
*** It's a good chance to compare Ge and Si features using the SAME SOUND CHAIN.  :)
Maroslav
#11
I'll try BC560's tomorrow
Signal chain is just guitar, fuzz and amp.
EDIT:
Here's BC560's.
Brighter, little less gain and more choky on chords
DDD
Thank you Maroslav for the BC560's test.
As far as I can hear, your Si version sounds very close to the original version of XFuzz.
Ge version seems to be much more interesting.
Maybe some filtering (HF cut) may improve the Si version, but I'm not sure that the Si version can be very close to the Ge one. It's a pity.
Maroslav
Board is already soldered  :icon_biggrin:
Elijah-Baley
Good job!
Quote from: Maroslav on May 24, 2015, 03:49:51 PM
I found AC121 on musikding, but the hfe is very low compared to your transistors. :-\ Are those much differents?
By the way... Is that a Crate amp? ???
Maroslav
Yes, It's Crate FW15R  ;)
I can't say anything about difference, those AC121's are only germs I have   :-\
ghostsauce
Sounds awesome!
Hmm, a name.. Fuzzymodo.
DDD
"...AC121's in my Dad's electronics stuff
Q2 hfe is 300 and leakage is 0,5mA..."
IMHO too high values (hfe and leakage current) for usual non-Darlington Ge trannies. It seems there's something wrong with the measurement method.
Maroslav
#18
Hfe is just slightly bigger than in datasheet.
Leakage is 500µA and 400µA so it's bad, but it happens
"measuring leakage a higher gain transistor will show more leakage, because the leakage is being amplified"
Q1 (325Hfe, 0,4mA leakage)
A first reading shows 0,98V
0,98/2,472=0,396...mA
A second reading shows 4,23V
4,23V-0,98V * 100=325
Q2(300Hfe, 0,5mA leakage)
A first reading shows 1,23V
1,23/2,472=0,497...mA
4,23V-1,23V * 100=300
DDD
Anyway, the circuit produces very impressive tones.
Great!
