Super Hard On not working!
Started by jonnygreentrees, June 08, 2015, 02:27:55 PM
jonnygreentrees
Sorry about the earlier link, please see full description below...
PBE6
LightSoundGeometry
dang, that is a lot worse than a pedal not working !
Jdansti
Sorry to hear that, but I think you have the wrong forum altogether. May I suggest:
https://www.pegym.com/forums/erectile-dysfunction-forum/
;D
radio
instead of retyping you could copy past your text.
Keep on soldering!
And don t burn fingers!
Tony Forestiere
Quote from: Jdansti on June 08, 2015, 06:18:58 PM
;D
AAARGGHH!! MUST...FIND...PICTURES...OF...CUTE...LITTLE...KITTENS!!!!
Almost better! Dang, John. Ya gotta warn people!
MrStab
Quote from: Tony Forestiere on June 08, 2015, 06:31:16 PM
is that how you handle erectile dysfunction?! lol
Recovered guitar player.
Electronics manufacturer.
Tony Forestiere
Quote from: MrStab on June 08, 2015, 06:53:26 PM
I refuse to answer on the grounds...
After seeing the pic in that link, I needed to find some MindBleach.  ;)
MrStab
now you made me look!! *gouges eyes out with spoon*
jokes aside, Jonny, you need to be a member to view posts on the forum you linked to, so maybe it'd be better copy/pasting your post here. this is a much better forum anyway.
Cozybuilder
"dang, that is a lot worse than a pedal not working !"
Beer up my nose on that one!
Jdansti
;D
For the record, I am NOT a member of that forum!  ;)
jonnygreentrees
#11
OK sorry, here goes!
Hi guys, thought I would finally take the leap and build a SHO clone as it is apparently easy. I've wired everything up using this schematic
which was included with a kit I bought off ebay.
It passes sound but sounds like an extremely gated fuzz and the volume pot doesn't seem to do anything :(
I did a continuity test to make sure I hadn't bridged any tracks on the veroboard and it seemed fine, any ideas where I should start troubleshooting?
here's the veroboard wired up
and here's the pot
I think I have got all the components in the right places, I was a bit confused about the pot though as the pedal came with two wiring diagrams, one of which showed a ground wire going from lug 2 to the jack which I added.
Going to take the switch out of the equation tonight and see if that narrows it down
And here's the wiring diagram which I followed and seems to contradict the pot wiring guide in the schematic  :?
and finally here's the switch. I'm aware there's a lot of excess wire, my plan was to make sure it all worked and then tidy it up although I'm not sure that was the best idea  :|
OK so I've taken the switch out of the equation and it is still doing it, currently got it laid out like this
Here's a shot of the rear of the veroboard
The pedal only makes an audible sound when I play really hard and that is the earlier described farty fuzzy sound like a broken speaker!
Farty, sounds like it could be the transistor is not biased properly.
Double check your values.
Could be a blobby solder bridge.
101 possibilitys.
jonnygreentrees
also the volume pot doesn't seem to do anything to the sound...
is it worth buying another transistor to try in the socket?
jonnygreentrees
also I've got a multimetre are there any values I can measure to see if something isn't working properly (and how do I measure those values!?)
LightSoundGeometry
#15
here is an example of  SHO I just did of you want to see one
mine has the power/smoothing cap problem going on ...I asked about it earlier and the forum said it was okay ..so I am selling it
but here is what it should look like
I can already see you are missing the first jumper right after C1
jonnygreentrees
thanks that's really helpful!
did you use the same layout as me?
I have two jumpers on the board, not sure if that's clear from the photo?
LightSoundGeometry
#17
no you got it then, its hard to see but there is only two
I think its a solder problem, your layout is sloppy and not tight. could be a case of not enough practice.
and dont buy any more kits , just buy all the pieces yourself
jonnygreentrees
yeah it's only my third time soldering ever and my first ever pedal build!
which bit is sloppy? tips for improvement welcome
LightSoundGeometry
well I would just practice taking components on and off ..solder/desolder
your joints are sloppy, pull everything tight and neat ..takes time. I am still new myself
