1980s DOD OD 250 replacement pot
Started by Luke51411, June 13, 2015, 12:06:55 PM
Luke51411
Just wondering if anyone if there is something like this available. It's a 500k rev log gain pot on the dod od250 but it is 90 degree pcb mount. It works as is but is scratchy. I want to keep it as close to original as possible and I wasn't able to find anything. I'm guessing I might just have to mod a 24mm solder lug pot to pcb mount.
Cozybuilder
#2
Luke51411
It's 90 degree pcb mount like the second one but 24mm
Cozybuilder
I couldn't find one. Could you replace the element in your pot with a new one from a Bournes pot? Or could you get a 24mm C with solder lugs, drill out the rivets, and rivet the correct lugs in place from an Alpha? A lot of busy work, but I'd likely do the same.
Luke51411
Quote from: Cozybuilder on June 13, 2015, 01:58:27 PM
Good plan, probably the best thing to do
armdnrdy
