Wet Only Switch for Reverb
Started by rthryhorysak, June 13, 2015, 06:04:45 PM
rthryhorysak
Hi, I was wondering if there was a way I could add a switch that would kill the dry signal and give me only the wet reverb sound with this box of hall thanks!
induction
An SPST just to the left of R9 should work. Make sure you don't disconnect pin 6 from pin 7 of IC1B in the process.
rthryhorysak
Ok thanks, I'll try it out later tonight
