no more tone stacks for me..
Started by deadastronaut, June 21, 2015, 03:41:26 PM
Quote from: MrBinns on June 25, 2015, 03:37:03 PM
>Have you considered rgs parametric eq
prametric eqs are so cool. I built and modified a pq-4 and loved it. I haven't tried rg's though. also I'm not op.
not hjacking but do you have a link to a schemo for that please MrBinns
Transmogrifox
Quote from: Kipper4 on June 25, 2015, 07:36:28 PM
Well I'm not MrBinns, but here's the link with a mighty nice read to go along with it.
http://www.geofex.com/article_folders/eqs/paramet.htm
trans·mog·ri·fy
MrBinns
#42
The pq-4 is from here: http://www.synthdiy.com/files/2007/boss_pq-4.png
I used TL074's for the op amps
To modify it, I took out the low section at the bottom and the presence section. I added another state variable filter for the bass section w/ .15uF caps. I was going to add a forth op amp to each section to control the q value. I need to re-bread board it.
I found the page(page 47): https://books.google.com/books?id=N7QgBQAAQBAJ&pg=PA48&lpg=PA48&dq=4+stage+state+variable+filter+with+q&source=bl&ots=FYNRNrk9ac&sig=7q7LzLuQz-HGkXXCBFVGTJQfG0E&hl=en&sa=X&ei=CMUZVfDVOdGKyAS4z4GYDg&ved=0CEkQ6AEwBw#v=onepage&q=4%20stage%20state%20variable%20filter%20with%20q&f=false
The three right most resistors I 'have' as 5K. The bottom three resistors from left to right I 'have' as 18K, 12K, and, 6K with a 100K lin pot in series with the 6K. After the 5K resistor, Vout, I have a 1uF(10uF)[20uF]cap to 500(500)[400]resistor to 100Kpot for highs(mids)[lows] sections. It's wired like the pq-4 C5, R9, pot, but moved over and with different values. I hope that makes sense. I drew it in a notebook so can't really upload it.
MrBinns
#45
Quote from: Kipper4 on June 26, 2015, 04:01:10 AM
Thanks Mr B
o and I want to say the q values I chose were 1/3-3octaves
it looks like it's closer to 1/6th and 2.5octaves. idk if those are good values or not. I haven't tried it out yet.
anotherjim
PQ-4 has some tapped (4 terminal) pots? Centre tap I guess, although drawn offset?
MrBinns
#47
Quote from: anotherjim on June 26, 2015, 10:28:07 AM
Is that what the part means? I just assumed it meant to ground the back of the pot or something.
They do have fancy pots though. dual gang 50K c taper, stacked with a 100K w taper, 9mm concentric pot.
I feel bad for hijacking this post. Should we move?
tca
#48
Quote from: MrBinns on Today at 10:30:43 AM
Quotefeel bad for hijacking this post. Should we move?
I guess so... is not easy to keep up with 2 topics in a linear medium.
Cheers.
This parametric has far less components than other options.  You can put these in series as mentioned in the original thread to get more bands.
http://www.diystompboxes.com/smfforum/index.php?topic=95483.0;nowap
QuotePQ-4 has some tapped (4 terminal) pots? Centre tap I guess,
I suspect the tapped pots are real.  You see these used time to time on professional Equalizers.   The centre tap stops the bands interacting with each other.  It tends to be a good thing.  Put it this way:  if you use non centre-tapped pots on a parametric circuit which was designed  for centre-tapped pots the result is no better or worse than any other circuit that doesn't use centre-tapped pots.  For a graphic EQ it would be a different matter.
Just got back from camping, great weekend...and now have my la3600 ic..
should get it breaded later.. 8)
Well i have it on breadboard, all working fine..
i stuck a buffer in front to lift it up a bit and tweaked to get better unity..
i'll use an opamp for the buffer and have a volume on it too..but for now this is how it stands
a bit of tweaking on cap values i think too.....thoughts?..suggestions?..
i have no idea of the ''actual'' freq's ...but its sounding pretty good so far 8)
tca
Nice!
What values for the caps? That C9=470u cap can not be right (missprint)?
Cheers.
tca
ah, ok!
The cap values are not "exactly" the ones I've calculated... but it could work nicely, it is all about compromise! ;)
Any first impressions? Control, responce...?
responds nicely..proper seperation etc..
once i swap the bjt for an opamp, i'll have a nice vol for 'make up' when scooping etc..
i just used that to get it going for now (nearest to hand bits :))
but yeah pretty cool so far..
any suggestions for other/better values while i have it on bread..
heres what i have so far..
47n     10n     3.3n    1n    220p
1uf     470n    100n   68n   10n
tca
> heres what i have so far...
My take on values:
30n  10n  3n   1n   360p
1.5u 470n 150n 6.8n 22n
Not much of a difference...
