deep blue delay only one repeat
Started by george79, July 14, 2015, 05:48:39 PM
george79
Hello,
just finished one deep blue delay.The pedal works good but there is a small problem.I can get only one repeat!!!i have checked solderings,pot,voltages at IC's and all are fine.I was build it in a tagboard using this http://tagboardeffects.blogspot.gr/2012/02/mad-professor-deep-blue-delay.html
any help please?im going to hit my head to the wall
George
I guess it's gonna be somewhere around that repeats pot and the nearby components, which is feeding the delayed signal back to the input.  Got a picture of your board (top and bottom)?  And which of the three payouts on IvIark's page are you using?
george79
hello,thanks for the reply,im usin the first with the volume control.i will post pictures.
george79
i have checked again and again for short circuits,chane the pot and nothin happens.only one repeat.all the other pedal works,voltages at IC's are correct.
Hmmm...  Nothing obvious that I can see.  I think it may time to try an audio probe to trace that delayed signal feeding back to the input.
Elijah-Baley
When I built the Little Angel (pretty similar circuit) I got no effects. I got the effect when I passed a knife between the traces, there were some invisible contacts. Do you have tried it?
Mike Burgundy
Tracing is probably easiest. From the mix (or delay level) pot you should be able to trace back and follow the delayed signal. From the delay pot go to the 2k resistor, other side, repeat pot wiper, repeat pot top (other side is grounded), 22n both sides, 5k resistor both sides. You have now reached the PT2399's input, so I'd expect the signal to disappear before that.
george79
That was a real help.THANK YOU!!!!!Problem solved.5K1 resistor cold solder.
Thanks again
Mike Burgundy
