Tap Tempo LFO. Call to PIC people (I know you are out there!)
Started by alparent, August 07, 2015, 08:59:28 PM
alparent
OK, this is knot really a new topic but I'm trying a new approach to my old problem.
First, I want to take this code http://www.electricdruid.net/code/TAPLFO2D.ASM and remove everything tat as to do with the clock output function (cause I want to use pin7 for something else.)
Second I want to use the freed Pin7 to control a 74HC595 using Roman Black shift1 http://www.romanblack.com/shift1.htm
This Pin7 will control the shift register and change LEDs every time the tempo multiplier is changed. (So I will be able to ID  what multiplier is in effect. (Quarter note, eighth note, etc)
This is my first try at PIC. Been learning a lot in the last couple of weeks, but assembler is not so easy!
Got myself PICKit3 and learned a lot. Spent the last 2 weeks at the RV and it rained the last week, so I had lot's of time to play with it.
But I can't wrap my head around what I need to do to get my project going.
Help from anybody would be more then appreciated.
Anything .......
Thanks.
SISKO
I havent read the whole code but the first thing i would do is to modificate this line
#define CLOCK_OUT PORTC, 3   ; Clock Pulse Output
It seems that CLOCK_OUT is used in the code so instead of erasing that line you may have to create a variable named CLOCK_OUT
Variables are created in the variables segment.
Then, the output of the shift1 would need to be sent to RC3
--Is there any body out there??--
