Banzai Univibe Kit
Started by warioblast, August 21, 2015, 06:38:11 PM
warioblast
Did you guys put the photocells flat or did you angle them ?
YouAre
Based on pages 9-11 from the document below:
http://madbeanpedals.com/projects/HarbingerOne/HarbingerOne_2015.pdf
I'd lay flat only if you're using a reflective shield.
warioblast
I have already read this doc, and so many others. But thanks for the reply. I guess I'll found out by myself.
induction
I found that laying them flat against the pcb gave a smoother warble. When they were pointed straight at the bulb it sounded too choppy. I did use a reflective shield though.
warioblast
Cool, thx. ;) May I ask what kind of shield did you use ?
induction
I used the lid from a spray can of air freshener:
It's brushed metal, so it's shiny, and it's exactly the right diameter. It was a bit too tall, though, so I cut it down with a dremel. It's held in place with some solid core wire soldered to the pcb.
warioblast
