Trimmer Tuning?
Started by bifbangpow, August 22, 2015, 12:18:47 PM
bifbangpow
I've come across my first build with a trimmer.  But I don't have an oscillascope. I'm told I need one to tune the trimmer properly.  Is this absolute? Is there no way to do this without one?
Keep on keepn on.
Fender3D
the real must for trimmers is a screwdriver :)
smallbearelec
Quote from: bifbangpow on August 22, 2015, 12:18:47 PM
What's meant is that you hang the scope on point in the circuit where something is happening, then turn the trimmer till the scope shows a particular waveshape. In many cases, your ears are a perfectly good measuring instrument for knowing when the trimmer setting is correct.
bifbangpow
All right, so I just pull out a screwdriver, adjust it a little, test the pedal and repeat until it sounds good? any tips?
Keep on keepn on.
armdnrdy
I think that it would be a great idea to let us in on what you are building.
You may...or may not need an oscilloscope to "tune" it in.
bifbangpow
Quote from: armdnrdy on August 22, 2015, 02:03:56 PM
It's a tonebender 3 knob clone.
Keep on keepn on.
FuzzFanatic71
Do an Internet search for the correct voltages for your transistor biases on a Tonebender MkIII circuit and tune with a multimeter to get them voltages. Then finish tuning by ear. If it sounds right then it must be right.
Why won't this @$&$ing thing work?
bifbangpow
Quote from: FuzzFanatic71 on August 24, 2015, 01:26:35 PM
ok. what would you suggest i use as my searching phrase, "tonebender mk3 transistor voltages"?
Keep on keepn on.
FuzzFanatic71
Or maybe Tonebender MkIII transistor biasing. Check here or the Tagboard effects forum. You will find it somewhere.
> any tips?
Get your buddy to play while you diddle the trimmer.
FWIW: there seem to be a billion "tonebender 3 knob clones" and not all have trimmers. WHERE did you get your plan? Do they have a clue?
bifbangpow
Quote from: PRR on August 24, 2015, 09:27:59 PM
> any tips?
Generalguitargadgets.com    http://www.generalguitargadgets.com/pdf/ggg_tb3_cp_instruct.pdf
Keep on keepn on.
