How do I test a circuit without the potentiometers?
Started by guidoilieff, August 24, 2015, 01:16:34 PM
guidoilieff
I made an Echo Base and I was wondering if there is a way to test the circuit without the potentiometers so I can be sure its working before wiring ( I used molex connectors where potentiometers are going to be).
So I guess where it says "Mod Speed" I just need to jumper pins 3 and 2, but in Mod Depth I have no idea what to do. Do i just wire pins 1 and 3 and put a resistor between pins 1 and 2?
Transmogrifox
The generally safest way to do if you don't mind hard-wiring a pot to its extreme is to stuff a resistor between 2&3 and a jumper between 1&2 .
...or to set it to the other extreme, jumper 1&2 and resistor to 2&3.
Get a resistor in the general ballpark of the intended pot value.
On Mod Speed you are in good shape with a jumper as you suggested, but you might consider using a resistor to set it somewhere in the middle of the pot range.
trans·mog·ri·fy
smallbearelec
#2
Please check out my notes in this article:
http://www.diystompboxes.com/smfforum/index.php?board=44.0
When I am building in the way you describe, I test continuity point-to-point as I build before connecting pots. The Molex headers are helpful with this because they make connections accessible from the top. Where a capacitor is part of a run, use the C scale of your meter to make sure that what the drawing says should be there actually Is. When done, go over the whole thing again...time-consuming, but it has saved me a lot of grief. Then create your connectors and you can test the whole thing before you box (Figure 50 in the article).
NB: I have available on my bench an input jack, output jack, power connector, stomp switch and a variety of pots already set up with plugs and ready to plug in for testing. I make sure that when I lay out a board, all of the off-board components connect in a standard way. Muuuuch more efficient, and still more helpful in avoiding mistakes.
Regards
SD
LightSoundGeometry
i would solder the pots leaving long enough leads to make a twisted/tinned connection to BB, then you can trim down access when putting permanently in curcuit . or like today in class, they gave us pcb mounted pots to stick in the BB which work really good for this application i noticed.
smallbearelec
Quote from: LightSoundGeometry on August 24, 2015, 10:08:39 PM
i would solder the pots leaving long enough leads to make a twisted/tinned connection to BB, then you can trim down access when putting permanently in circuit.
That's one way, though not one that I like. I prefer a termination of some kind on the board for test purposes and to solder to. See figure 82 and following in the Breadboard-To-Box tutorial:
http://diystompboxes.com/beginnerboostbreadboardtobox/BeginnerBoost.htm
This is often done for production, yes. However, I recall some of the engineers here recommending against putting board-mount pots on the main circuit board because the connections tend to go intermittent. I think a "daughter" board for controls was recommended.
You are on your way to to learning the enormous range of choices that you have in designing even a simple piece of gear. I hope you enjoy your course and eventually profit from it.
GibsonGM
+1    Terminal clips are awesome...very reminiscent of the early Peavey stuff - makes things easy to work on/modify later!!  And much less likely to go flaky on you.
guidoilieff
Thanks everyone. I forgot to ask how to bypass a millennium bypass. Do I just jumper those connections? (in the upper left part)
