popping sound in my tonepad tubecreamer
Started by jan007magic, August 27, 2015, 11:03:00 AM
jan007magic
hey guys, I have a problem with my TS that I jsut completed.. it has this popping noise when i turn on the volume.. here's the soundclip for reference
Kevin Mitchell
There is simply not sufficient information about your project for a diagnoses.
Please review this thread and share your findings. Someone will surely try to help you through it. It would also be helpful if you supplied more info on the issue and not just a sound clip of you turning a volume knob. EX- how does the circuit perform other than your 1 claimed issue.
Debugging Info
pinkjimiphoton
if it's popping, probably a cap. as it charges and discharges, it will make a popping sound.
bad solder is likely. try and reflow the cap(s) in the power supply (if applicable) and see if it stops. if it doesn't, reflow the whole board. if it stops, cool... if not, you can replace any electos and you should be good to go.
Slava Ukraini!
~Jack Darr
