Binding Screws / Chicago Screws
Started by LightSoundGeometry, September 09, 2015, 03:15:01 PM
LightSoundGeometry
before I spend 10 bucks on these things, what size does the forum recommend? 1/2 " , 3/4"  for a TWN 1590b or 1590bb
Are you just looking for the backplate screws for Hammond die cast enclosures? Datasheet- 1/2" 6-32
http://www.hammondmfg.com/pdf/1590BB.pdf
LightSoundGeometry
#2
Quote from: davent on September 09, 2015, 04:14:50 PM
nope, was going to mount a board to the enclosure like you see on some of the fancier fuzz boxes out there. looks like 1/2 in or possibly 1/4 " would give enough to fasten strip board to top of enclosure and clear the pots.
for example, this dude uses all three types of fasteners I am aware of which includes what looks like industrial pop rivets
https://www.facebook.com/jimmy.behan.fx
peterg
Cozybuilder
I like mounting boards on 9mm pots for tiny box builds, but use standoffs as well. Rather than drill the face, I mount the standoff to the board and glue in the standoff with JB Weld. A drop on the bottom and let it cure, remove the board, and fill in around the standoff using regular masking tape for a dam- obviously the standoff is located near the enclosure side. If you purchase longer standoffs, you can trim them to size.
Quote from: Cozybuilder on September 09, 2015, 06:16:54 PM
I glue in standoffs as well but have also drilled through and countersunk for the screws to mount flush. Using 4-40 hardware.
dave
