Problem with a veroboard honey bee
Started by alfonso_bundis, September 23, 2015, 07:45:01 PM
alfonso_bundis
Hello everyone,
I build a Honey bee following this layout:
http://2.bp.blogspot.com/-wzJfRxAyO8E/T5bN9Atv0EI/AAAAAAAABSg/Kfn52ftJfnw/s1600/Bearfoot+Honey+Bee.png
However when I tested it I only got noise. The Nature pot seems to be working but I do notice any changes from turning the Drive nor Volume pots.
I believe that this schematic for this vero is similar to this one, only starting from C5:
http://4.bp.blogspot.com/-BGtE8eHdasM/TxCinQLXguI/AAAAAAAAAeI/MjzR0nMy8L4/s1600/hot%2Brodded%2Bhoney%2Bbee%2Bschematic.png
I tried to use a probe and I got clean sound up to pint 3 of CA3130, pin 6 gives only noise.
The voltage readings are the following
T2
d   8.98V
s   8.96V
g   8.14V
IC1
1    8.96V
2    8.43V
3    8.50V
4    8.80V
5    8.96V
6    8.50V
7    8.98V
8    8.53V
any suggestions on what should I try to make it work?
Thanks for your help.
> No ground?
My guess also.
> d   8.98V
> 2    8.43V
When ALL pins are a lot closer to +9V than to zero, lack of ground seems likely.
(..... I smell a rat ......)
interesting use of a ca3130.
++1 on the grounds.
" I will say no more "
alfonso_bundis
Thanks to everyone. I checked myground connections and indeed i had done a mistake with them. Now it is working perfectly
