Help with Boss CE-2 Voltages
Started by astrodave, September 25, 2015, 07:33:21 AM
astrodave
Hi Could any one please have a look at the voltage reading im getting from my pedal. The Problem im having is no chours affect at all just clean sound from both on and off.
Power =9.27v
IC1
1=5.39
2=4.47
3=4.46
4=0
5=4.47
6=4.47
7=3.56
8=9.27
IC2
1-8.65
2=4.98
3=8.89
4=0
5=5.00
6=7.78
7=9.12
8=9.27
IC3 MN3007
1=7.97
2=5.93
3=0.99
4=1.00
5=0
6=4.03
7=7.52
8=7.52
IC4 MN3101
1=7.98
2=4.05
3=0
4=5.92
5=0.32
6=7.10
7=2.47
8=1.05
Q1
E=4.98
B=5.29
C=9.27
Q2
E=5.06
B=5.61
C=9.27
Q3
E=0.19
B=0.18
C=8.99
Q4
E=2.12
B=2.65
C=8.00
Q5
E=0
B=0.4
C=6.72
ANY HELP PLEASE
Thanks Dave
nickbungus
I'm out tonight but will sort it tomorrow.
Can you please tell me what voltage you set your trimmer to and where you read the voltage for setting it?  I'll set mine the same and match the dc input to.
To the extreme, I rock a mic like a vandal.
Light up a stage and wax a chump like a candle.
Fender3D
0.99 V bias voltage is too low for a proper working MN3007...
voltage at pins 2 and 6 are different (they should be more or less the same) check for a proper square wave with a o-scope
astrodave
Ok Thanks guys
I set the voltage at pin 1 on IC1(4558). and I will check pins 2 and 6 with an oscilloscope. Thanks once again
Dave
astrodave
Hi Fender3D
Nice square wave at pins 2 and 6
pin2 =5v
pin6= 8v
Dave
