The Popping Brian May Treble Booster
Started by Elijah-Baley, October 20, 2015, 05:21:29 AM
Elijah-Baley
Thank you. ;)
Maybe I do some test tomorrow.
Elijah-Baley
Perhaps I solve the popping!
I put with the test lead an 1M resistor on the footswitch, as unduction's suggestion.
Quote from: Elijah-Baley on October 20, 2015, 10:09:23 AM
So, in few words, and if I got, I can put the output pulldown resistor directly on the footswicth, from lug top right (output) to lug bottom center (ground). Of course I'll try it with the test leads, and see what happens.
It seems enough for stop the pop noise.
I wanna be sure. When I got it, I'll post the picture, inside and outside.
Thank you, PRR. I hope I have learnt something from your lessons.
Thanks a l
Elijah-Baley
antonis
Well done..!!  :icon_wink:
but, maybe board's secure by only pot's lugs doesn't guarantee long and healthy life..
Elijah-Baley
 ??? I know about the pot, it is my first attempt. It's been a bit hard solder it on the board.
The board doesn't move and I like it, but probably I'll never do it again.
