Convert line level circuit to high impedance
Started by armdnrdy, October 20, 2015, 02:24:53 PM
armdnrdy
I worked out a project for a Sonic Maximizer that is designed to work with -10dBu line level.
The input impedance of the stock circuit is 47K....not good for guitar.
The original circuit is built around a proprietary IC (NJM2153) which includes the input buffer and the resistor that sets the input impedance. This configuration can't be changed.
I was wondering if including a JFET buffer in front of the existing circuit will solve the impedance problem.
Here is the input of the existing circuit. The components in the yellow box are included within the IC.
ashcat_lt
Quote from: armdnrdy on October 20, 2015, 02:24:53 PMI was wondering if including a JFET buffer in front of the existing circuit will solve the impedance problem.
Yep!
I personally would use an opamp, but either will work.  You might want to give it a little bit of variable gain.  Guitars range in output levels from a pretty low to maybe a bit high compared to -10dbu.
armdnrdy
Thanks Ash,
I would have rather used an op amp but...I am limited on board space. This was sort of an afterthought.
