series resistance ?
Started by LightSoundGeometry, October 21, 2015, 07:57:13 PM
LightSoundGeometry
hello, looking at this part of the schematic here :
can I use the series circuit equivalent if I do not have a 560R on hand? I do have a 470R and a 100R which puts me only 30 ohms off ..and would 30 ohms be too much ? I admit I do not know the tolerance limits of said math equation
thanks in advance
Granny Gremlin
Um, 470+100=570 and 570-560=10 Ohms difference not 30.
10 Ohms would be about 1.8%. Unless it's super critical for some reason that escapes me it should be no biggie (looks like an old schem back from the days where most things used 5% carbons - you'd be using 1% right?  You'd still be doing better).
my (mostly) audio/DIY blog: http://grannygremlinaudio.tumblr.com/
LightSoundGeometry
#2
my bad on the math lol..
I have both 1% and 5% but am using the 1% on this one
appreciate the quick response gremlin ..this forum is fantastic!
modified
its 47R4 + 560R5= 607 ohms
Rt of 607-470-100 = 37 ohms
so I would have Rt of 570 ohms
the important thing is I can use the series resistance to formulate equivalent R ..I forgot about the 1K pot that should be calculated as well? it is also in series with the r4 and r5
It's audio; and it is a guitar booster.
20% is normally plenty good.
Much of the Good Old Stuff was built with 10% parts only because 20% parts were going out of style.
540 to 470 is just 19% different. Use 470. It WILL work.
LightSoundGeometry
Quote from: PRR on October 22, 2015, 12:08:12 AM
Thanks Paul, got her boxed up and she sounds like a dirty old Rat :) :) :)
