Low voltage reading on Q1b on mayer fuzzface
Started by Mikey707, October 22, 2015, 02:35:22 AM
Mikey707
Hi all,
This is my first post and my first build and would appreciate some help.
The FF is on a bread board and is producing very low fuzz levels but at a good volume.
The voltage readings i have measured are:
Q1c- 2.32
Q1b - 0.04
Q1e - 0
Q2c - 5.04
Q2b - 2.32
Q2e - 2.29
I am using a trim pot at Q2c to bias.
I have switched the ac128 around and get the same readings.
They are matched with leakage of around .5ma and have hfe of 105.
I believe my issue is the low voltage at Q1b but no matter what i change the reading only varies by .01 v
I would appreciate any help that can be offered.
Cheers
Electric Warrior
It's not only that. Q1C is really high (usually between -0.3 and -0.6V in a germanium Fuzz Face) and so is Q2e (should be under -0.5V)
Mikey707
Thanks for the replies.
I have had a chance to fiddle a bit and i now get these readings
Q1c- .52
Q1b - 0.02
Q1e - 0
Q2c - 5.7
Q2b - .54
Q2e - .46
The sound I am getting is a boosted signal with more bass coming through with just a bit of fuzz in the background.
Does anyone know why I could be getting such a low reading on Q1b when I am quite close to the voltage readings I should be getting.
Thanks again
Electric Warrior
Looks good now. Except for Q1b of course. Not sure what's wrong with it, maybe the leads of Q1b and Q1e are touching?
I would suspect the resistor from Q2 E to Q1 B; or the input cap.
Mikey707
Thank you again for your time.
I thought a little more info might help.
I have started from scratch on a different breadboard and new caps.  Below are the new voltage readings
Q1c- .55
Q1b - 0.02
Q1e - 0
Q2c - 4.5
Q2b - .55
Q2e - .48
The resistors i am using are
95k at Q1b usually a 100k
65k at Q1c and Q2b usually 33k
470 as usual from neg power supply to a 3.8k resistor which is a 10k trim pot to Q2c
B1k pot for fuzz A500k pot for volume
2.2uf polarised cap at input and 2 10uf in series at the output of the 1k pot.
Im starting to think I have knackered my Ge.
Electric Warrior
Try swapping Q1 and Q2. If Q1 is broken, the voltages will tell you :)
Mikey707
Hi,
I swopped them around and the readings were pretty much the same and when i rechecked them 20 secs later the voltages on Q2e and Q2b had jumped 1.2v.
Any ideas on what is going on.
