MN300x VGG generation
Started by jona, October 27, 2015, 02:33:01 PM
jona
Hello folks.
I am wondering how accurate the VGG supply has to be for a MN3005 design.
thank you.
Jona
Fender3D
You just need to be near Vdd+1V.
Watch out, Vgg will affect bias voltage requirement  AND overall gain (or loss) vs. clock.
jona
Did you mean VDD -1V?
"Vgg will affect bias voltage requirement  AND overall gain (or loss) vs. clock."
Does that mean that the closer it is to the exact value, the closer to the spec/requirements the bias/gain will be? Or should it be trimmed?
I am thinking of a design without the MN310x type parts.
thanks again Fender!
Fender3D
Quote from: jona on October 27, 2015, 02:49:43 PM
Vdd for 30xx is negative (-15V max) then Vdd+1 = -14V
I guess you should always trim for the best bias point...
What I meant is that with a "near optimum" fixed bias, you might as well fine tune it by varying Vgg.
jona
ha... I missed the 'negative' part! Revisiting my initial design now, not quite sure how to deal with that. Thanks!
armdnrdy
Quote from: jona on October 27, 2015, 05:09:15 PM
Look to factory BBD circuits for guidance.
You feed the ground pin positive voltage and the VDD pin ground.
The BBD doesn't know the difference. The VDD pin just has to be more negative than the ground pin.
12Bass
Quote from: Fender3D on October 27, 2015, 02:43:26 PM
Is it reasonable to assume that the same is true for other BBDs like the SAD1024A?
In an effort to maximize signal to noise ratio, do you know the relationship between Vgg and overall gain vs. clock noise?  In other words, does signal gain go up or down relative to the clock signal as Vgg is made closer to Vdd (i.e. Vgg = 14/15 x Vdd => Vgg = Vdd)?
Do you have a suggestion for the optimal ratio of Vgg/Vdd, or this value something which varies from device to device?  IIRC, datasheets generally suggest Vgg = 14/15 x Vdd.  Just curious if optimal results can be obtained empirically.
Fender3D
Quote from: 12Bass on October 27, 2015, 09:42:56 PM
Well, SAD's datasheet says "it is recommended that Vbb be adjusted approximately one volt lower than Vdd"...
Quote from: 12Bass on October 27, 2015, 09:42:56 PMIn an effort to maximize signal to noise ratio, do you know the relationship between Vgg and overall gain vs. clock noise?  In other words, does signal gain go up or down relative to the clock signal as Vgg is made closer to Vdd (i.e. Vgg = 14/15 x Vdd => Vgg = Vdd)?
Actually, my main concern was the signal loss when the clock was higher than ~1MHz, thus I was looking for a solution...
I tried the TCE approach, by rectifying the clock signal and feeding it to Vgg: it helped raising the gain when raising the clock, just not enough to supply the gain needed for a "steady" response... (TCE uses an OTA also...).
This approach might as well help when you have a clock wafeform not "optimal" ('cause capacitive loading or lack of buffers), but I didn't tested it for this... I used no buffer between clock and BBD.
