Little to no volume sweep - Boss FA-1 Clone
Started by Jmkrull, November 04, 2015, 12:01:03 PM
Jmkrull
Just built this FA-1 clone and used the pot value in the schematic for the volume knob and notice that all of the volume sweep happens in the first 10% of the turn and the rest of the way does nothing. Should I change this out for a linear pot or change the value or something to get a better sweep?
https://aionelectronics.com/wp-content/uploads/2013/01/aion-prism-fa1-documentation.pdf
No that should get proggesively louder the more you turn it up.
Check the pot with your meter......
Jmkrull
Will do. I'll check on it when I get home. Thanks
Also verify R5 R6 are the correct values.
If R6 were 47K instead of 470K, not much happens in the top of the volume knob.
