top-mounting hardware
Started by djp8djp, November 10, 2015, 10:01:27 PM
djp8djp
Thanks guys. And sorry, I thought when looking at Cozybuilder's photo that the skinny enclosed jack was the Lumberg. Oops.
Anyway, those Lumbergs look pretty nice. But I'd also like to try those enclosed jacks, second from the right in Coxybuilder's first photo.
Would that be Smallbear's "1/4 in. Mono Enclosed #111", SKU 0603, http://smallbear-electronics.mybigcommerce.com/1-4-in-mono-enclosed-111/
... or is it from BLMS "1/4" Stereo Switched Enclosed Jack -5 Pins", http://bitcheslovemyswitches.com/#!/1-4-Stereo-Switched-Enclosed-Jack-5-Pins/p/25664011/category=5027593
Thanks !
Cozybuilder
#21
Quote from: djp8djp on November 11, 2015, 10:15:15 PM
Thanks !
Both the ones you referenced are like the middle one in the photo. The second from right came from an inexpensive kit from China- they are really small. I have a few of them, PM me if you want a couple.
Edit: Small Bear has one very similar that looks like it would work: http://smallbear-electronics.mybigcommerce.com/stereo-low-profile-pc-mount/
Quote from: samhay on November 11, 2015, 05:24:17 PM
what happens when you put another pedal to the right of this (nice build btw) with its stomp in the middle..hmmm...
i have big clumsy feet, and don't do ballet or the shoes ;D
i like RG's suggestion for ''pedalboard specific pedals'' with the jacks on the bottom..
good idea. and tidy..8)
samhay
If you aren't too drunk, you can turn this on by stomping in the middle and catching the foot switch with the edge of your shoe - it's a momentary switch.
It's not ideal, but there wasn't any room left - the reverb brick is under the board next to the switch. In any case, it is a usually-on effect, so not too much tap dancing required.
Perrow
Granny Gremlin
A whole bunch of Cholos have the weirdest boners right now.
my (mostly) audio/DIY blog: http://grannygremlinaudio.tumblr.com/
I have seen winklepickers with the toes curled back over the top of the shoe, looking like something mediaeval from a fairy tale somewhere.  And the people wearing them were part of the toughest Italian street gang in Toronto.
Granny Gremlin
There are Italian street gangs in Toronto?  That self identify via whimsical footwear?  News to me.
Quote from: samhay on November 12, 2015, 08:29:55 AM
If you aren't too drunk, ......
you got me right there... :)
samhay
Well nobody likes a sober astronaut.
Anyway, with a space suit on, you would need a 1590DD-wide box to prevent you mashing the pedals to either side.
Quote from: amptramp on November 12, 2015, 02:19:36 PM
You might need winklepickers to operate the pedalboard:
Quote from: amptramp on November 12, 2015, 06:10:54 PM
this coulda been me in me yoof! the boots! [I had some matchbox flint stuck to the under-rise of the heel ....]
" I will say no more "
Cozybuilder
Quote from: Cozybuilder on November 11, 2015, 11:32:04 AM
Just an idea, but for small box builds without a battery, is there any reason you can't use a stereo jack for in and out, making your own cables to go to other boxes in the chain? There are many examples of Stereo Input jack guitars, with 2 mono output cables from the stereo plug. That might be an answer to your 1590G box.
There is an adaptor from a ¼" Stereo to two ¼" mono, this might make the quoted suggestion viable for gigging:
http://www.ebay.com/itm/1-4-Mono-Splitter-1Male-To-2-Female-1-4-Mono-Jack-Mic-Cable-Guitar-Adapter-/271887554313?hash=item3f4dc2d709:g:SDAAAOxy63FS9Z80
tubegeek
Quote from: R.G. on November 11, 2015, 07:15:07 PM
Frankly, given the state of pedalboards, .... It makes a lot more sense to put them on the *bottom* where the cables can be routed under the surface of the pedalboard.
I like this a lot BUT:
When assembling the pedal flying leads to the lid will carry input and output to these jacks. I'm worried this is a potential point of failure.
But so is everything else..
