New Component in DIY Layout Creator???
Started by chuckfalcon, November 29, 2015, 10:35:09 PM
chuckfalcon
Hi everyone.  I am trying and having no luck in making a new component in DIY Layout creator.  I am trying to make a 3 pin circular socket for transistors for my Fuzz Face board.
I have tried just using the current circular transistor  component.  I can move the pin spacing but I can't make the circle any bigger.  I have also tried using circular tool making the size I want and put 3 dots on it.  When I make the component that way and "save as template"  it doesn't seem to save ANYWHERE, I looked under every component.
Does anyone have any ideas or help?
your better off asking in the DIYLC THREAD.
im sure the guys will have a solution for you..
i think 'TEMPLATES' just saves the board....i may be wrong though.
CodeMonk
Quote from: deadastronaut on November 30, 2015, 05:10:04 AM
I've saved 1n34, 1n914, 1n4xxx as templates under the diode component.
Select the component, select edit menu, give it a name. done.
However, saving 3 different components as one.....
Lemme try...
Nope.
You can save shapes as templates, pads as templates, but you can't save 2 components even if they are the same type as a single template.
config > snap to grid "off". this will allow you any size circle, anywhere you want. it will drive you mad, though, at least till you set it back to "on".
Katy who? what footie?
