Diy practice amp with mark hammer's chaos as distortion.
Started by distortionhead, December 15, 2015, 12:51:30 PM
distortionhead
Guys.. hey Im looking to build a small practice amp. Thinking of using the chaos as preamp. What would be a good small power amp LM386 or TDA2822. Suggestions welcomed...
Elijah-Baley
I built a Punch Amp, and I'm modifing a Smokey Amp DIY adding a gain and a volume master control.
distortionhead
Elijah-Baley
Jfets? ???
Punch Amp is TDA7052A based.
Smokey Amp (and Little Gem, Ruby, Noisy Cricket...) LM386 based.
Those are 1 watt and 1/2 watt. Just a mini amp.
distortionhead
Punch ,ruby, noisy cricket uses uses a jfet buffer right .Thats what i was pointing about... Since i can't get any jfets trying to stay away from those deigns..
Quote from: Elijah-Baley on December 15, 2015, 01:38:20 PM
The LM386 are an 8pin dip (dual in line pin) chip. Not a jfet 😀
samhay
As you are planning on using the Chaos as a preamp, you probably don't need the buffer.
I got carried away sorry guys. I didn't look at the schematic
distortionhead
Thanks guys.. :D will build it by this weekend and get back..Any other suggestions for preamp other than chaos???  :icon_question:
antonis
Quote from: distortionhead on December 15, 2015, 09:41:04 PM
If you are saying that Mark's Chaos doesn't provide enough distortion as a preamp then I personaly have to revise the meaning of distortion.. :icon_eek:
distortionhead
distortionhead
Elijah-Baley
I'm building my Smokey Amp with a 1k pot instead of a SPST switch and I added a 100uF as power filter for cancelling the noise coming from the PSU.
distortionhead
I made it same as the layout. no switches.  ill add filtering afterwards...
distortionhead
Hey guys been busy with Christmas n new year... Got around building it today.. wired it up like this... No big  surprise... No Sound.... Not even a hiss... Dead silent...
distortionhead
#15
Can't upload pics sorry . Will post voltage by tomorrow... One more noob question.. to measure voltage. Black lead should go to the ground and red to various pin right ?? Noob learning..
Quote from: distortionhead on January 04, 2016, 12:46:14 PM
Yep.
BTW, there are many, many posts advising how to insert pictures (I've made several myself): where and how to host them and how to form the correct markup.  Have a little play with "Search".   :)
