Heatless Toner Transfer
Started by J0K3RX, January 05, 2016, 05:29:17 PM
bloxstompboxes
Yeah, that's exactly it. If I remember correctly it was a long white wire and you do put the resistor in series. Cut the wire and splice the resistor in there. You will still have to run the board through several times. I usually do 5 or six passes. Works pretty well.
stringsthings
Thanks.   I wasn't sure if I had the right wire.  Over the holidays, Walmart put it on sale for $15, so I figured it was worth it even if I screwed up.
FiveseveN
