Overly complicated Filtering and Pol Protection?
Started by lars-musik, January 26, 2016, 08:09:05 AM
lars-musik
I want to shrink my noise gate into a 1590a and try to save some PCB estate. I don't understand quite a lot on the decimator schematic found on Revolution Deux:
But the assembly in the lower left corner really baffles me:
Is this some kind of filtering/polarity protection thingy? If yes, wouldn't one diode suffice and couldn't be the parallel caps (410uF) be replaced by a single 470uF?
Not sure about the diode overkill, but I think the last three 100nF caps are intended as decoupling caps located close to each IC.
those diodes looks like a pair of braces (D1, D2) for when your belt (D14) has burst.
granny at the G next satdy.
Quote from: duck_arse on January 26, 2016, 09:07:20 AM
How much current can a 1N914 take anyway? If you're going to short out the power supply when the connections are reversed, it might be a better idea to put a current limiting resistor in series with the diode, no?
digi2t
Quote from: bluebunny on January 26, 2016, 08:19:42 AM
Frostwave Resonator is set up like that too. It's bipolar powered, so there's two caps right next to each IC, one for each rail.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
QuoteHow much current can a 1N914 take anyway?
yeah, odd that it isn't a 1N400x. and it seems multi-cap PS filtering is usually a 100µF and 100nF ceramic disc, not a 10µF electro, correct?
Other versions of the schematic like this one https://guitar-gear.ru/forum/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=31065 don't have D1 and D2. I guess they're just an error on that schematic, they don't do anything useful.
lars-musik
Quote from: slacker on January 26, 2016, 01:04:33 PM
Hi Ian,
that's a nice looking schematic. You think this one is correct? I have never seen this before!
Sorry I don't know, I just googled decimator schematics to see if any of them showed those two diodes connected differently.
QuoteHi Ian,
and that schematic has a proper rectifier diode being used (FR207), as opposed to a switching diode (1N914)
lars-musik
I found another one that also differs from the other two. But tidy also. Especially the send/return op amp configurations look different.
http://www.efekty-diy.pl/pdf/Decimator%20G-String.pdf
Might I bring that to vote? Which schemtic would YOU think worth the effort?
A 1N914 can clamp a battery good enough that your pedal may not fry.
In this day of 1.6 Amp wall-supplies, a 1N914 is not even a joke.
There are better polarity protections.
