Progress! (Its all your fault, by the way)
Started by slashandburn, January 31, 2016, 11:45:58 AM
slashandburn
So I decided to finally share some pictures of my builds. I've been hovering around here for about a year and half, finding this place when I was looking for help building a Ruby and. I thought this would be a shortcut to building tube-amps. It's turned out to be a rather lengthy detour but I'm in no hurry to move on. There's way to much fun to be had here and I feel I'm still just treading water (in the shallow end!)
Anyway. You lot can hold yourselves somewhat responsible for these. I seriously doubt I'd have made it this far without the help of this forum. I started etching less than a year ago, I couldn't bear working with plastic boxes, aluminium tape  and stripboard any longer. I really wish I'd made the jump sooner. I quite enjoyed getting creative with MS Paint too though I should really look into learning something more sophisticated for graphics. So much to learn.
These are all LM386 based amps a-la the Ruby and Noisy Cricket.  I had no jfets so adopted an OP-amp buffer which quite quickly morphed into a Tubescreamer gain stage. They don't really do clean but being a bit of a metalhead that doesn't really bother me. They're also really handy for hooking my audio probe up to. I stuck a Big Muff tone control between the pre and power amp chips too. I'm not sure I'm totally happy with it, I had to improvise with capacitor values and didn't keep a good record of deviations from the original circuit, but it's functional at least.
I have a bunch of other low power power-amp chips to play with but haven't really found the time or motivation yet. The 820M sounded okay on the breadboard but I haven't spent much time with anything besides the 386 to be honest.
After I got those working I moved onto simple pedals with a view to better understanding some of the more fundamental stuff around using transistor as buffers, boosters and distortion circuits. I'm not sure I learned anything besides "maybe go with something more spacious than a 1590A for your first pedal" and "if you insist on cutting off redundant solder lugs from jacks, cut the correct ones" but if nothing else I got some decent looking shiny boxes.
I digress, the LPB1 is the only one properly finished and fully operational. You'll need to excuse the green stripes too, it's a gift for a fan of a certain football team.
On the Fetzer I foolishly didn't leave enough clearance for the Jack sockets from the 3PDT. I've managed to squeeze in a DTDT and just need to sort out a millennium bypass.
Anyway. Cheers Everyone. My knowledge is still lacking in a lot of areas but you've helped me make massive strides in a pretty short space of time, often without me even having to ask anything.
Cozybuilder
Quote from: slashandburn on January 31, 2016, 11:45:58 AM"I feel I'm still just treading water (in the shallow end!)"
Great line, could be the basis for a country song
slashandburn
Ha. Thanks. How about:
My feet can touch the ground but it don't really feel too stable,
I dunno why I etched, I should've just went with a label.
stringsthings
Those etches look really good.  I've been doing this for years and still haven't etched an enclosure.
slashandburn
#4
Thanks David, they're far from perfect. And I'm not showing you all the ones I made an arse of. I didn't expect to get so into it. It should've been simply a means to an end  but has spiraled into a hobby in itself.
It could have turned out so differently if I had somewhere local that sold decal paper. There's something wrong with a town where you can easily buy Ferric Chloride and Caustic Soda on the high-street but not decal paper.
the hoops!
you've been holding out on us, but now we all know what to expeckt! they look the biscuits.
" I will say no more "
slashandburn
#6
Quote from: duck_arse on February 01, 2016, 09:42:34 AM
Ah if my track record is anything to go by, this could be as good as it gets. Once I get stuck into more complex circuits I'd expect my care to detail to slip. I do appreciate the compliment though. Assuming you like biscuits.
the hoops!
It's been dubbed "Jinky". Hey, since we're talking football, here's a work in progress. God knows who he'll be managing by the time it's finished, hopefully he's still gegenpressing!
slashandburn
I hadn't done much for a while then from out of nowhere, this happened. It's all set up to be Anchovie's Noise Ensemble. Seems I'm getting better at this.
