Mono-Stereo Junction Box Build Problem
Started by JCGH, February 04, 2016, 04:27:20 PM
JCGH
Hi all,
I was wondering if someone could help me as I'm still fairly new to this. I'll try and explain the problem without making it too confusing...
I'm building a junction box for a friend which works as follows:
Input > True Bypass Switchable Buffer > Send (to pedals)
(From pedals) Return R + Return L > 470R MF Resistors > SPST Mono-Stereo switch > Out R + Out L
The Input > Send works just fine. However, I'm having trouble getting the second part to work.
The Return R > Out R works fine when the switch is in the one position (I can't remember which one, I believe it's stereo) but not in the other, let's assume it's mono.
The Return L > Out L does not work whichever way the switch is and after an audio probe test I have found that the signal even at the tip of the cable is significantly reduced compared to that at R Return, which I do not understand!
I tried it out in reverse as well (as in I plugged the guitar into out and the amp into return) and the same thing happened...
I'm not sure whether it's something to do with ground? Currently, all the jacks + buffer + buffer switch are ground together; should I separate the grounds of the Input > Send and the Returns > Outs?
Any help will be much appreciated! Cheers.
Transmogrifox
A diagram would help so we can see how the SPST stereo/mono switch is (or isn't) working.  Are you just switching the Left (mono) output between L return and the center tap between the 2x470R?
470R is a pretty low value for most stompboxes to drive.  You probably want your stereo-mono "mix" resistors on the order of 470K (1000 times larger value).
Then after that you may want to (at the very least) use a JFET buffer, and better would be a booster for gain recovery.
Grounds should all be tied together.
trans·mog·ri·fy
