Could somebody check my orange squeezer layout?
Started by dbp512, February 07, 2016, 10:54:35 AM
dbp512
It seems like I've bitten off more than I can chew this time. I got the parts for a simple orange squeezer a while ago, but before I got around to building it I found schematics for modified versions that had attack and decay controls. I quickly abandoned the original in favor of this, but unfortunately there were no vero layouts. I decided to attempt to make one myself, and after several revisions I eventually found one I thought would work. I finally finished it, but the only noise I can get out of it is a repeated clicking sound. I'm not sure if the problem is in my soldering/assembling, or if the vero layout is to blame. If somebody could take a quick gander at my layout and check it out, I'd be grateful. I'll update with the voltage of the pins, but since I have my computer on hand and the vero is suspect as well, I figured someone might find the problem already.
Dave's not here, man
On some nights I still believe that a car with the gas needle on empty can run about fifty more miles if you have the right music very loud on the radio
- Hunter S. Thompson
is it possible that the stop-hole (can't remember what they're called) you drilled in the vero, just below the IC, for a ground connection to pin 4, has also prevented the jumper from pin 4 touching the ground strip?
also, for what it's worth, i'm not sure how many vero boards you've made but they are just about the most failure-prone way to hook everything up. that's not a dig, just sayin' that you might find other ways of making boards less troublesome (after the learning curve)
