Perfboard Switches?
Started by thehallofshields, February 11, 2016, 11:58:37 PM
thehallofshields
Hey guys, I'm simplifying my designs and really want to be able to add switches to boards rather than making them external.
A compact DPDT Slide-Switch with simple leads and compatible with 2.54mm spacing would be ideal.
I can't find any switches out there that will fit in standard Perf. Do they really not exist?
mth5044
Googled 0.1" breadboard switch and got a ton of links. This is the first one, maybe it will work for ya.
https://www.adafruit.com/products/805
thehallofshields
I have some like this. The pins are too close together. They fit in the bread and not the perf.
mth5044
Hmmm that's odd. The product I linked to says 0.1" spacing, which is the same as IC's and whatnot. If they can't fit on breadboard, I'm not sure why they couldn't fit on perf. Have a caliper?
thehallofshields
Shoot. Why can't I make sense of this? I'll try putting those switches through the perfboard again and reply back.
I used one in my Blackstone OD build in the Pictures thread:
I got it from Bitsbox in the UK.  So yes, they do exist.   :)
