flipping emittor and collector with a switch?
Started by Fndr8875, March 12, 2016, 03:17:39 PM
Fndr8875
I just built a Soda Meiser with a pcb from Rullywow. I wanted a hyperion but cant find a pcb for one. I was watching some Youtube videos and found the Vintage Fuzz, then found out its a soda meiser with the 4th transistors flipped around. Im knob on perfboard itd be simple, but the only idea i can think of on a premade pcb, i socketed my transistors, but could i stack the socket and and 2 wires coming from the E and C to a Spst switch in between the first and second socket? or would that interfere with the original EBC layout?
peterg
allesz
Yes, it is possible: look to the "psylocibe" mod on the codpiece, a bosstone variation made by codtone and captain peyote.
ichbindaz
Fndr8875
think imma add another 3pdt switch, 2n2907 EBC on top lugs, CBE on bottom and wires in the middle row.
ashcat_lt
Since the B doesn't switch, you only need two poles unless you want to add an LED indicator, or also switch something else.
