Digital Potentiometer Help Needed
Started by LiquidMetal, March 20, 2016, 05:46:32 PM
LiquidMetal
Hello,
I am looking to build a simple volume pedal (250k) using an Arduino-controlled digital potentiometer. I found a couple of 250k digital pots, but none of them is available in a DIP package. The closest value in a DIP package is Microchip Technology MCP41100 (100k, 256 taps).
My first attempt was using a LED-LDR couple (Vactrol), but after some reading found that a digital pot would be a much better match.
Any advice how to find a non-SMD 250k digital pot or how to use a 100k in that situation will be greatly appreciated.
A good buffer before and after any expression pedal, not only a digi-pot one, is a good idea. It has the side effect of removing any significant dependency on the pot's actual value as long as it's above about 10K.
You could use the circuit of Figure 9 here:
http://www.ti.com/lit/ds/symlink/dac0808.pdf
This entire article shows how to use a multiplying DAC like the DAC0808 (8-bit) as a programmable gain amplifier as well as a digital filter, programmable sinewave oscillator, pulse-width modulator and log amp.  You can extend this to the 12-bit DAC1208 for 12-bit systems.:
http://www.ti.com.cn/cn/lit/an/snaa097/snaa097.pdf
The DAC0808 is a standard 16-pin DIP package, available cheap and everybody and his dog carries it.
miech
Don't use a digipot as a volume control. They crackle and pop when you change the value.
