Really dumb question regarding diodes
Started by Giglawyer, April 11, 2016, 03:35:32 PM
Giglawyer
I am looking at possibly building a Black Arts Pharaoh.  The vero schem that I have calls for a rotary switch to select between six sets of clipping diodes - germanium, silicon, LED, etc.  One set is supposed to be MOSFETs.
MOSFET diodes?  What is a MOSFET Diode?
ANy help would be appreciated.
Check out my builds - http://www.giglawyer.com
Kevin Mitchell
I think it just means a standard N-channel JFET.
But don't take my word for it! I've never seen the description "MOSTFET diode"
GGBB
It means using a MOSFET as a diode. Google it (no offence intended) there are plenty of resources on it which will explain it far more clearly than I can.
FiveseveN
Ice-9
It means that it will be using a MOSFET transistor in the circuit for clipping instead of a diode when switched to this position. This can produce a different sound to the diode. Look up the circuit diagram for a Zendrive for an example of how this looks.
www.stanleyfx.co.uk
Shaka 5 has mosfet diodes.IIRC.
Edit
Yeppers it do......
http://www.muzique.com/schem/shaka5.gif
Giglawyer
Thanks all.  That's what I thought.  Its just that on the Vero layout, they used a standard diode symbol, so I thought I was missing something.
ALL triodes can be diode-wired.
Vacuum, BJT, JFET, MOSFET..... Even hydraulic control valves.
Long ago it was common for transistor radios to use a half-dead transistor as the detector diode. It is still a fine trick for a bias diode.
When MOSFETs cost several dollars each, nobody thought to mis-use them as 2-terminal diodes. I guess times have changed. The diode-wired MOSFET is not quite like any of the other available diodes. Also a higher threshold voltage than most.
Kennt82
The OCD also uses them as clipping diodes.
You're building the Pharaoh SUPREME then?  I built one recently and "mosfet" is my most used setting.
