TDA8932 amp
Started by potul, June 10, 2016, 02:02:20 AM
potul
Hi folks
does anyone have any experience with these?
Are they any good?
http://www.ebay.com/itm/Digital-Amplifier-Board-Module-35W-Mono-Power-amp-Low-Power-TDA8932-12v-24v-car-/331591959628?
For the price, I just grabbed a couple of them. We'll see how they perform...
Mat
TejfolvonDanone
I know this won't help but i "love" how people call class D amps "digital" amps. It's like calling a BBD chip a digital chip...
...and have a marvelous day.
Quote from: TejfolvonDanone on June 10, 2016, 03:09:15 AM
I would raise my middle finger to such people.  That's a "digital sign", btw...   ;)
TejfolvonDanone
Quote from: bluebunny on June 10, 2016, 09:19:13 AM
That means four. I just never get why people say "4" to each other.*
But not to run really away from the topic as i could tell it is a class D amplifier chip with factory example circuit. It can't be that bad.
*https://en.wikipedia.org/wiki/Finger_binary
J0K3RX
Quote from: potul on June 10, 2016, 02:02:20 AM
Hi folks
Are they any good?
Mat
Glad you posted a link to that, I'ma get me a couple of those! I can think of a lot of cool things to do with'em! :icon_twisted:
To people who say bahhh to these little chip amps... I guess ignorance is bliss :icon_wink:
This little HoTone Heart Attack nano head has a TDA2003 for the power amp. I purchased one of these new for $100 and I have to say I am impressed as hell with it!! Check out all the youtube videos, you'll be hard pressed to find any that sound bad..
At the same time I am also kinda put off on making pedals, preamps etc... why you may ask? Because, it's really hard to top this especially for only $100... if only for myself that's fine cause I love messin with this stuff and selling a few here and there but, I'm glad that I don't rely on making these things for my main source of income!
GiovannyS10
Seems the TDA2003 have a good sound for the price. The Hotone make good things to too little pedals. Haha
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
www.instagram.com/allecto
> say bahhh to these little chip amps...  has a TDA2003 for the power amp.
Not all chips the same.
The TDA2003 is an *analog* car-sound chip, and developed to be not-too-nasty when over-driven.
TDA8932 (any chip which needs ferrite cores) is a *digital* (really PWM) amplifier and overloads very differently. It also has much better efficiency, especially at less-than-max output (better battery life!) and is tending to be cheaper because heat is almost a non-issue.
potul
Yep
they are much more efficient. Almost no heat is dissipated..
I tried it today and it worked pretty well if you stay in the clean area.
I need to test it with a bigger speaker,.. as the one I used is rated for only 3w, so I suspect some of the distortion was coming from the speaker itsef...
But it looks promising
Mat
Renegadrian
bought one, waiting for it...
just bought one too.... 8)
looks better than my tda3030a that ive been messing with.
for 2 quid its worth a test... 8)
blackieNYC
Renegadrian
Usually TDAs require some heatsinking of sort, those new chips Are less keen to overheat, As far as I read...So I'm eager to receive it and to try it!!! 30W!!! Want to try something like the stompamp (italian product, 349 euros)
tca
> Does anyone have any experience with these? Are they any good?
Yes and yes.
potul
Great!
I'm planning to build a new 20-30 W amp, I will give it a try, and probably add some preamp to it, ROG style.
Mat
tca
> just bought one too
I've bought 10.
Honest amp, flat colorless sound, linear response, runs at low temperature and does what it promises...
But I keep returning to much simpler designs;)
Cheers.
@tca:
what power supply are you using with it?.
stringsthings
Quote from: J0K3RX on June 10, 2016, 10:30:51 PM
Just checked out some Hotone videos.  Very impressed !
tca
A 19V 6A laptop power source.
potul
@tca
are you using any kind of heatsink with it?
I tried the one I have wihtout any heatsink, and it was running really cold. But I didn't push it much, I must admit
tca
No heatsink... but I use it for regular audio (5W tops), not guitar.
