Pedal I own has cement putty over the entire board and felt glued to the bottom.
Started by Belanger, June 16, 2016, 06:05:30 PM
merlinb
Quote from: Belanger on June 17, 2016, 09:55:05 AM
Also he said " I add the putty because of people who feel the need to steal my circuits"
Suuure they do.
whoisalhedges
"No, it is NOT just a Tube Screamer... First of all, Tube Screamers don't have the entire circuit encased in putty!"
theehman
At the risk of cheesing someone off,  I'm going to guess it's a Metal Pedals Jersey Devil.
Ron Neely II
fx schematics and repairs
GGBB
Quote from: theehman on June 21, 2016, 09:26:56 AM
Now we're getting somewhere!  :)
Maybe the Bomb Shell - the right side pot is a pull switch.
Quote from: thermionix on June 20, 2016, 11:52:56 PM
The 10v caps might be wired in series, but not too many people would do that.
better goop that idea, just in case someone steals it.
" Hence the duck effect. "
Ben Lyman
Quote from: GGBB on June 21, 2016, 09:52:31 AM
...the right side pot is a pull switch.
And the clay is the shrapnel... you got 7 seconds to throw it away!
        -S. Vai
thermionix
It's not clay or putty, it's C4!  OP don't try too hard to get it off!
dbp512
Quote from: thermionix on June 21, 2016, 03:18:44 PM
Some people try way too hard to protect their stolen secrets
Dave's not here, man
On some nights I still believe that a car with the gas needle on empty can run about fifty more miles if you have the right music very loud on the radio
- Hunter S. Thompson
Joe
J0K3RX
No need to de-goop, Just apply 9v and press the foot switch :icon_twisted:
Ice-9
+1 , My vote
Vitrolin
QuoteIt was a expensive pedal to. Luckily I bought it on Black Friday.
if i bought a expensive pedal, came home and saw that it had a circuitboard lying loose in the enclosure, with som felt on the solder side.
im guessing that the felt is to avoid the circuit shortening with enclosure, its not going to work for very long.
Felt will last a lot longer than foam. Foam-"insulated" gear is not too rare.
