Cap question
Started by Mark Hammer, June 29, 2016, 05:41:46 PM
So, I was trying to match some caps for a semi-parametric EQ.  I put some "greenies" in the meter, and their value stayed stable very shortly after insertion.  I put some small ceramics in, and the values started low and just climbed and climbed and climbed.  It's not hot indoors.  I wasn't touching them post-insertion.
So why is the one stable and the other not?  DoI need to wait for the meter to come to rest before assuming the actual value of the ceramics?
Gus
What brand, model number meter?
What type of ceramic? This matters a lot.
armdnrdy
My Fluke 87V doesn't "like" capacitors in the pf range.  >:(
Quote from: Gus on June 29, 2016, 06:10:17 PM
Fair point and fair questions.
It is a "generic" 50v, +80/-20% disc, about 3mm across, with a "y5V" temperature coefficient.  In this case, 15nf.  The DMM is an older 3-1/2 digit Micronta (Radio Shack).
dschwartz
Y5V ... I use X7R on my builds with no issues
Tubes are overrated!!
http://www.simplifieramp.com
I had a 2n2 ceramic disc, from a bag of 100 "the same", in a 7555 doing some non-critical timing. the one in was drifting everytime I switched on, others from the bag were stable, and much closer to the marked value. very ordinary caps indeed.
" I will say no more "
Gus
I don't know how the RS meter measures capacitance.  Does it have DC on the leads http://www.nandblog.com/avoid-y5v-capacitors/
some links from a search for "y5b ceramic"  look at the voltage and temp curves
http://www.johansondielectrics.com/basics-of-ceramic-chip-capacitors
http://www.niccomp.com/help/VoltageCoefficientofCapacitors-032012-R1.pdf
snap
Maybe you get a more consistent reading, if you shorten (discharge) the leads of the cap before measuring? Might be some "static" in them, that fools the meter?
12Bass
Apparently your capacitance meter is a cork sniffer....   :icon_mrgreen:
It is far better to grasp the universe as it really is than to persist in delusion, however satisfying and reassuring. - Carl Sagan
dschwartz
Question..is the cap in question being measured in the circuit or by itself?
You can't measure capacitance if the cap is soldered or connected to something else..it gives random readings
The cap isn't installed in anything other than the socket on the meter where you insert the leads.
