Tonepad Fuzzface difficulties
Started by uzdgtrz, August 12, 2016, 09:13:32 AM
uzdgtrz
Hello : this tonepad Fuzzface (positive ground version) is my first stompbox project, and I'd like to get it powered from a domestic outlet (not a 9v independent battery).
I don't understand how to create the layout : the schematic seems to display an actual battery, whereas I thought domestic outlet wouldn't make it necessary. (I'm not looking for a multi-pedal power supply, as this fuzz is the only pedal that will be in my rig)
Please help me out  :icon_neutral:
Welcome!
If this really, really is going to be your only pedal and nothing else will share the power supply, then connect the "PSU +" to GND on the circuit, and "PSU -" to -9V on the circuit.
Voltages are all relative: there are no absolutes.  A "positive ground" circuit just means that "ground" is the most positive part of the circuit.  (Compare this with the majority of stompboxes where "ground" is the most negative part.)
uzdgtrz
Thanks for the quick answer bluebunny  :) so I assume PSU + goes with the GND located under the INPUT ?
JerS
Yes, you can connect the positive terminal of the power supply to the sleeve of the input jack (shown on the schematic) to make the positive ground.
uzdgtrz
#4
Cool : now how can I add an on/off switch and a signaling LED (or else) to this circuit ?   ???
Oh and are there voltage values that matter when picking up an Ac adapter ?
Use the wiring diagrams at Tonepad for details on how to wire up footswitches, jacks and LEDs.  Make sure the PSU you get is putting out a regulated 9V DC.
