Creepy Fingers FuzzBud clone
Started by maiko, August 28, 2016, 09:51:38 PM
maiko
Ive tried to build this
https://effectslayouts.blogspot.com/2015/06/creepy-fingers-fuzzbud.html?showComment=1472435123231#c3282104233703515494
Its a really loud and awesome sounding fuzz love the crakling.
But cant get much range from the pot.    All the way down it has no output.  and even if i so much as just touch the pot it starts to scream at about 1/10 a turn its tooo loud.      Ive tried a bigger pot (100k) and a  Smaller pot (20k) it behaves the same.    Ive built it exactly to this layout.
Has anybody else built this here.   Did you have the same observation?
pappasmurfsharem
Quote from: maiko on August 28, 2016, 09:51:38 PM
Is your POT 100K-B(Linear) or 100K-A(Log)?
Based on what you've said, I assume you're using a Linear POT, where-as in most situation the level output usually a logarithmic.
It will have the same overall function but the volume change will be much smoother.
maiko
Check it is a linear
Will try this tnx
