Regulated power supply questions
Started by juan_felt, September 02, 2016, 02:36:07 PM
merlinb
#20
Quote from: juan_felt on September 08, 2016, 03:25:54 PM
Merlinb, thanks for your reply. I didn't know this happened, why is this? Is it always half the current?
No it's not always half, but half is a good rule of thumb.
If you want to get technical it depends on the type of rectifier, size of the reservoir capacitor (or choke if it's a choke-input power supply), and the ratio of the load impedance (Rl) to the transformer's internal source impedance (Rs). The maths is frighteningly complicated because a rectifier is a non-linear circuit.
But the end result is that for power supplies of 'typical' i.e. practical design, the AC current in the transformer will be between 1.5 and 2 times the DC current, so we use 2 times to err on the side of caution.
juan_felt
Hi,
Again, thanks for all the replies. I'm still a bit confused with the design. I know what to do with the circuit, but the 9v/18v switching part I'm a bit lost.
My idea is to do something similar to the T-Rex Fuel Tank Chameleon, but without so many different outputs (maybe 2 or 3). How do you think they do the switching? For what I've seen, they use dip switches with resistors, so I guess that they change the Adjustment lug in the LM317. What I don't understand is why they state that in 9v and 12v they have an output of 300mA, and in 18v 150mA.
If I wanted to accomplish those voltages, with those amperes, what size transformer should I buy?
Here are some pictures of the power supply.
http://1.bp.blogspot.com/-Meg5dR6Luro/UlO_eJc_9aI/AAAAAAAARJw/Kxofri-lCes/s1600/Guitar+work117.jpg
http://1.bp.blogspot.com/-TF2HM_0Q8mc/UlO_dhejE8I/AAAAAAAARJs/zCUeUHZKCEM/s1600/Guitar+work116+copy.jpg
http://1.bp.blogspot.com/-kfUxwtoZfgQ/UlO_ch-5RUI/AAAAAAAARJg/gqd-Vd7K9sM/s1600/Guitar+work115.jpg
Again, thanks!
merlinb
#22
QuoteWhat I don't understand is why they state that in 9v and 12v they have an output of 300mA, and in 18v 150mA.
At first I though it might switching in a voltage doubler to acheive 18V, which would halve the available current. However, there are only five big caps (one for each regulator), so I suspect that's not the case. Maybe if you try to suck the full 300mA it woudl pull the voltage down too far, causing the regulator to drop out?
Keeping it as simple as possible:
Take your target output voltage, e.g. 9Vdc;
Add 3 volts to this (regulator dropout voltage);
Add another 1V to allow for ripple;
Add another 1.4V to allow for rectifier drop;
Multiply by 1.05 to allow for mains brown out;
Divide by 1.35 to convert from peak to RMS. This is your nominal transformer voltage.
Take your target DC output current;
Multiply by 2. This is your nominal transformer current.
(You'll need to select the nearest off-the-shelf values, obviously. You don't find many 11.2V transformers in the catalogues!)
juan_felt
Thanks a lot Merlinb,
Your reply is very clear, I'll start designing the power supply with those calculations. I'll post how it ends up working!!
Cheers!
