Little Gem MKII not working on the BB
Started by Ben Lyman, September 07, 2016, 03:20:46 PM
Ben Lyman
Sounds bad, gated, splatty, LM386's getting painfully hot to the touch. Ive stripped it out, double checked, triple checked, shortened up, neatened up, rebuilt 5 times... same results.
Got 2 LM386N and 2 LM386L from Tayda and they all worked fine for my Smokey with several different speaker combos.
Can one of you please take a close look at this schematic and tell me what could be missing/mis-labeled? Does it look perfect as it is? I think people have made this amp before
Scemo:  http://www.runoffgroove.com/littlegemMK2.png
        -S. Vai
boppy100
Ben Lyman
Looking at the schematic linked, I hooked up the LM386 pictured above to the "plus" side of the speaker and the lower LM386 to the "minus" side labeled speaker. tried a 4" 8ohm, 2x 4" 8ohm in series and parallel. Also tried a 4" 30ohm and a 12" 8ohm, then 2x 12" 8ohm in series.
        -S. Vai
Speaker polarity does not matter.
The schematic is fine.
What did you *really* build (repeatedly)?
Great heat does suggest reversed *power* polarity (how would I know that?).
Ben Lyman
Quote from: PRR on September 07, 2016, 11:44:39 PM
I don't know Paul, I'm mystified. I moved on to the Ruby, seems the same but simpler, only 1 chip and works fine as I BB it, as does the Smokey. Ruby has a 100nF pin 7 to ground and a 220uF from out pin (5) to speaker+ ...remove it and chip melts down.
Please tell me where the Little Gem MKII differs in that it does not need a cap there or why there is nothing on pin 7
        -S. Vai
> I moved on
Movin too fast for me.
Is this one of those nebulous projects that has no Volts in it? LINK
The cap on pin 7 (bypass!) defines gain and suppresses power supply crap. It really should be used.
Pin 5, Output, sits at DC voltage of half supply. If you run this through 8 Ohms to ground, way too much useless DC current flows. "All" single-rail grounded-load audio amps need an output cap. The bridge-tie (two outputs) variant has both outputs at 4.5V DC, so no DC current flows in speaker or amplifiers. (Why I was askin about Volts.)
Ben Lyman
Sorry, "moved on" was poor choice of words. I just mean that I'm trying simpler things for a minute to make sure I understand this chip.
Right now the Ruby is kicking serious butt from my BB into a 12" 8ohm Mesa cab, loud and clean or louder and raunchy.
So I am almost prepared to tackle the LG MKII again. No caps needed on the out pins of both chips, got that.
So... pins 7 and 7... I should have some caps there on each chip going to ground?
Sorry if I misunderstood that part but I will give it a go with caps if that's what you mean.
thanks
        -S. Vai
First figure out why the dual-amp plan gets HOT.
Voltages are clues.
Ben Lyman
#8
ok, will do, thanks
I had to work fast because the chips were heating up, I think it is only number 2 chip that gets hot.
Readings were moving around a lot and I just had to grab a number sometimes and move on.
Lets call the upper pictured IC #1 and the Lower pictured #2
Q1
D 2.0
S -4.0
G -4.5
IC1
1 4.2
2 5.0
3 5.0
4 5.1
5 2.0
6 4.1
7 -3.6
8 -7.0
IC2
1 5.1
2 5.7
3 5.9
4 5.9
5 .06
6 4.5
7 -1.0
8 3.2
        -S. Vai
balkanizeyou
the voltages look way off - are you powering it with a dual power supply? You should be getting supply voltage (9V) at pins 6 of both ICs, pins number 4 should be at ground - in your case pin 4 is at HIGHER potential than pin 6, which is weird to say the least.
Check the power supply connections, also a picture of the build would be a great help
Bad (or no) ground connection?  There's nothing much that looks like 0V, like IC1.2, IC1.4, IC2.3, IC3.4.  No obvious power at pin 6 either.  And given that IC1.3 is connected directly to IC2.2, they should have exactly the same voltage.  Plus what Paul said about the output pins.
If this is all on a breadboard, I'd be inclined to take a deep breath and start over.
Ben Lyman
Thanks guys, ya I know it's all way off, numbers were changing with the temperature, I have taken several breaths and start-overs already. I'm using a 1-spot, it measures 9.4v
I just used these chips to BB a Ruby on the same BB and everything worked at that time.
Thanks DA, I will lay it out one more time exactly as you show.
        -S. Vai
no probs, thats how the schemo says it is..
good luck. 8)
Ben Lyman
Same results. Seems like IC2 is always the culprit, I switched speaker wires around and IC1 got hot. I thought maybe my 4ohm cab and/or speaker cable was loading it down or something? I don't know, I tried the shortest speaker cable I have, about 3 feet, and same results.
I thought it might be cool to try a panoramic shot of the BB:
        -S. Vai
How come you dont have jumpers from the top power rails to the bottom ones mate?
+1 and make sure you have continuity across those rails
some breadboards are split in the middle...
Not just the jumpers in the middle Rob.
My BBs dont have continuity from the top power rails to the lower (+ and -)
Ben Lyman
#18
good eyes, that was a test  ;)
actually, this bb has continuity horizontally across and the reason I didn't put a vertical jumper was because I only used the top for plus and the bottom for minus... but, umm... oops, I just noticed the 100uF needs some attention. I'll fix that but rest assured it will not change anything.
Thanks again guys
Updated pic with 100uF corrected. Same problem
        -S. Vai
I burnt my thumb print off earlier tonight by badly connecting LM78l05 regulators. Dammed those Underside view datasheets and my stupid old eyes.
At least I could commit a burglary without Thumb print evidence now.
Sorry I cant be more help with the debug.
Have you tried it with some different speakers.
Are some of the designs resistor rated higher than our std 1/4" watt?
I hope you get it sorted mate.
