Switching board
Started by ShOrEbReAk, November 12, 2016, 07:02:45 AM
ShOrEbReAk
Hey all
Was watching that pedal show on the YouTubes and thought hey I wonder if any one has attempted something like the G2 Gig Rig switcher?
I think it would be fairly complicated but thought I'd ask so if it has been done someone can pint me in the right direction. I would like to try build one as I don't have the 1500usd to buy one hahaha
Would be great to see pictures of completed styles of switchers.
I build cause I'm to pov to buy one! Plus electrocution is a great learning tool
Lothric
I am doing switcher on atmega8 atm... Hard shit to acomplish but definitly there will be no effect order in my one...
send from Tapatalk
ShOrEbReAk
Lothric- Wow cool. Did you build your own schematic or did you find one to modify. Have you started a thread in regards to your building progress?
I think I will try a few more pedals before I attempt something that's going to be that difficult.
Troy
Lothric
Just used one of the arduino projects, you can easy Google it, builded breadboard,will post video later on
send from Tapatalk
Lothric
sorry for late reply... also sorry because vid is in polsish language (I was recording it to show it to my friend) but You can see. On left hand side green diodes are memory banks, also I didnt use relays yet, instead I used LED's on the right hand side which are "simulating" coil circuits. In this case You have 4 loops and 4 memory banks.
Everything here is based on the original project I have found here:
http://www.instructables.com/id/arduino-programable-5-pedal-switcher/
Good luck with your switching system, Rob  ;)
potul
Something even bigger is cooking in this thread:
http://www.diystompboxes.com/smfforum/index.php?topic=112598.0
Including chaning pedal order and parallel routing
ShOrEbReAk
Wow cool gives me some reading and researching to do. Cheers again for the input guys
