Buffered power supplies for multiple circuits?
Started by mg.audio, December 05, 2016, 07:52:46 PM
mg.audio
Just for fun, I'm planning a pedal that will have a bypass stomp-switch and just one rotary switch to select between six different buffers (two NPN buffers, two FET buffers, and two Op-Amp buffers). The idea is to pass it around my guit-fiddling friends and see if they can tell the difference between different buffers. There are a couple questions that popped up while thinking about the build. One is whether I should give each circuit it's own buffered power supply. Since we're talking about audio circuits that are supposed to be super-transparent, is there a good reason to do this? Are these circuits going to interfere with each other in any way?
For example, this link goes to the schematic for the Boss DS-2 -> http://www.freeinfosociety.com/electronics/schemview.php?id=132  What I have in my head is simply multiplying the buffer consisting of Q7, R15, C14, and C16, to get a 9v supply for each circuit. I'm assuming I would just have to change the value of R15 to keep the voltage at 9v instead of 8. The follow-up question I guess, if I'm wrong here, is when DO you need buffered power supplies?
The second thing is pretty simple and probably exposes my ignorance... when using a 2P6T rotary switch to select between 6 different FX loops, with the poles being the master in/out, is there a better way to avoid popping than putting a bunch of, say, 10M resistors between the pole and throw 1, pole to throw 2, pole to throw 3, etc...?
There is an unavoidable 0.6V drop.
In general you can't isolate without losing some.
Yes, I do think that power filter will work for you.
bool
Suggestion:
halve the R15 (i.e. ~2k2)
quadruple the C14 (i.e. ~47uF)
use a high-gain high-current transistor (or a ...3904)
