Rangemaster noise - my guitar or my pedal?
Started by alange5, December 14, 2016, 10:51:42 PM
alange5
My rangemaster hums/buzzes. I built it negative ground with NPN germanium (hfe around 120, leakage less than 100ua, biased somewhere between 6-7v).
I own two strats, and with both guitars, I get a lot of buzz/hum (not normal treble boost hiss) in positions 1, 3, and 5. It's nice and quiet in positions 2 and 4.
I'm wondering if my single coils are the sole culprits, or if it's possible I have an issue in my pedal grounding. If it was indeed a pedal ground issue, would I still get noise with humbuckers and strat positions 2 and 4?
a2music
If it's quiet in the humbucking positions then what you're hearing is more than likely just the natural byproduct of single coils and a treble booster. When you turn yourself so that the pickups face north or south does the hum get quieter? I'm a strat/tele player and I have the same issues with the Rangemaster. It's a noisy pair but the good news is that drummer drowns it out.
Sent from my iPhone using Tapatalk
alange5
Quote from: a2music on December 15, 2016, 12:48:53 AM
yes, a bit.  Noise doesn't disappear, but it does change.
I don't have a truly isolated/regulated power supply, so I'm sure that contributes.  I've powered it with a 1spot and a Joyo DC Brick knockoff, and the Rangemaster is equally as noisy with both.  I also tried a battery measuring about 8v, and the noise was still there.
In the humbucking positions, it really is dead quiet, with just a tiny bit of hiss.  So I can safely chalk it up to the single coils?
GibsonGM
Quote from: alange5 on December 15, 2016, 11:24:00 AM
I'd say guitar, or cable.  POSSIBLY (but not likely) there is 'something wrong' at the jack or something...but SC's are inherently noisy.  I leave such effects OFF until the drummer says "1, 2, 3, 4!" and then stomp them on  ;)    Or use a noise gate.
One thing I do with Teles and Strats is to completely shield them, under the pickguard, w/aluminum foil and spray adhesive.  Pickguard also.   This quiets them down A LOT, in my experience.   Not silent, tho, no!   More like less susceptible to bar light transformers, etc.
