Tiny giant pcb to speaker
Started by Mgt280y, December 26, 2016, 05:41:53 PM
Mgt280y
Just wondering is there a "best practice" in terms of connections and wire type, for getting from the spkr pads on my tga pcb to the speaker
Thanks all
> "best practice" ... tga pcb to the speaker
Tiny Giant, neither side of the speaker is at-ground, so 1/4" plugs are not-right.
"Best Practice" would be speakON, professional connectors made for speakers.
Home-brew not being kicked around, I might favor "5 way binding posts" as found on most older pro power amplifiers.
I don't see how wire-type from PCB to connector matters a bit. Smaller than #30 is at some risk of melting, but that's mechanically dubious anyway. Fat #10 wire would tend to rip off the PCB pads. Lamp-cord may be a fine size, or cheap speaker wire.
Wire from amp to speaker, all the usual constraints. Will it be stepped on? Is it very long (>20 feet)? For amp next to speaker, lamp-cord is slightly over-kill but cheap.
Mgt280y
Right I have used the biggest wire that fits into the pads on pcb I am running a very short length to the speaker max 12 inch
In terms of speakers I think I'm going to use 2x
http://celestion.com/product/161/bl10100x/
So they are 8ohm does any one know what will work best wiring wise wire for 4 ohms or 8ohms meantioned in another post tga running at 15v so 20watts at 4 0hms or 12 watts at 8 ohms, it is a practice cab so I am looking for quality over quantity
anotherjim
Any multi strand 2core flex will do. Consider what 20w (ish) stereo units come supplied with  - bell wire! Choose a size that's a good fit to the pcb holes. I prefer a twisted pair, because chip amps can pick up RF from phones via the speaker wires and the twisting cancels it out some. Round sheathed 2 core lamp flex is twisted while figure 8, obviously not.
Although I see commercial stuff with spade crimps on speaker terminals, they are often a loose and poor fit - usually the male spade part of the speaker terminals is just too thin - even on name brands like Celestion. I would wrap & solder.
Are you building a combo? Even if it is, I find it far more convenient to have a speaker jack at the amp chassis rear and a floating jack plug to the internal speakers. Solid-state amps do not mind being run without speaker load, so a permanent hard-wired speaker connection only makes any future repair work harder. I've seen horrors in name brand combo's where the speaker connection is all internal and -  to make matters worse -  is hot glued where it leaves the amp chassis into the speaker compartment.
I don't think it is critical. Really-- I would find an old lamp and cut the cord off. I realize US lampcord may be smaller than in the UK, but at few-foot distance there is NO difference. 4 feet of our #16 is 0.016 Ohms, which is so much-much less than 4 Ohms that the electrons won't notice the trip.
EDIT -- OK, the smallest UK lamp "flex", 0.5 mm^2, good for 3 Amp loading (which would be almost any domestic lamp) is 0.05 Ohms per meter. That's still insignificant.
If you have to run across a large stage, I would reach for 1 mm^2 10-Amp stuff, my #18.
Note particularly that in a Guitar (or Bass) amp you do NOT want too good a connection from amplifier to speaker. We want the speaker cone to have "tone", not do exactly what the amplifier says.
