HELP Identify identify this component from existing pedal
Started by tenser75, December 28, 2016, 11:46:01 AM
tenser75
I noticed inside a Malekko pedal they are using this small component...very smart way to connect the PCB ground to the enclosure, in case you are using Neutrik style jacks
can you help identify this component? where can I buy it?
those two lips are "springy" so they touch softly the chassis
armdnrdy
Search for SMD contact.
I just sourced something similar from Mouser to facilitate adjustment of a small PCB making contact with a lower PCB.
This is for an adjustable LED/LDR/Vactrol test bed that I have in the works.
When I use non grounded jacks, I use a through hole battery spring contact for grounding the enclosure.
davepedals
dave
tenser75
Quote from: davepedals on December 28, 2016, 03:19:15 PM
I would have never guessed, jeez!
Thanks google... not even Mouser sales people were able to help me!
