Tonepad Tremulus Lune Symmetry Pot Wiring
Started by cnspedalbuilder, January 08, 2017, 04:23:35 PM
cnspedalbuilder
Hello, I got the Tremulus Lune PCB from Small Bear. Here is the layout on Tonepad.com: http://www.tonepad.com/getFile.asp?id=84
As you can see, the pot wiring descriptions are, well, incomplete. There are two pots shown in series for "Speed". I assume from the schematic that the second pot is for the "fine" setting. I'd like to drop the fine pot and wire with a symmetry pot. I've seen the instructions for doing so here:
http://commonsound.org/tremulus/symmetry.pdf
That diagram shows wiring with a fine pot and it assumes there are solder points on the PCB for the fine pot. My PCB only has solder points for the "Speed" pot.
My questions:
1. With the Tonepad PCB how would you wire the speed and symmetry pots?
2. What pot values would you use?
3. Is the symmetry mod even worth using? I hate wiring pots so if the mod is not worthwhile, I'm happy to just stick with 4.
cnspedalbuilder
Whoops, just found this thread:
http://www.diystompboxes.com/smfforum/index.php?topic=65107.0
But I'll still ask: Is the symmetry mod worth it? Does it add a lot of versatility to the sounds?
cnspedalbuilder
In case anyone out there is reading, here is the symmetry pot mod:
Can I do this with a DPDT? I'm thinking an on-off-on so that I have diodes on lugs 1-2 and 5-6, so when the switch is engaged it either ramps down or up and in the off position, there is no ramp engaged? I think a switch would be more useful than a pot, because it seems like in-between values would be too subtle to detect.
cnspedalbuilder
i.e. wire the DPDT like this:
               o--|<--o
Speed 2--o---------o--Speed 3
               o-->|--o
midwayfair
You only need a single pole, on/off/on. You hook it up exactly like the pot.
