"Soft-touch" momentary foot switches with double throw (DT)?
Started by Phoenix, January 27, 2017, 06:41:50 AM
Phoenix
Hi everyone,
I was wondering if anyone knows who stocks a "soft-touch/click-less" momentary foot switch which has two throws (NO & NC). Number of poles isn't important, SPDT, DPDT or 3PDT would all be fine.
I can find plenty of SPST in either normally closed (NC) or normally open (NO) configurations, but I need both terminals on the one switch for a project I'm working on.
The usual suspects of Smallbear, Tayda, BLMS etc don't appear to carry this type of switch - if I'm mistaken, please let me know!
Any help is greatly appreciated!
Phoenix
Quote from: EBK on January 27, 2017, 08:05:11 AM
Smallbear has a bunch of momentary stomps:
http://smallbear-electronics.mybigcommerce.com/momentary-stomps-1/
Thanks Eric, but Smallbear only have two momentary switches that are explicitly "soft-touch" - implying that none of the other switches are. Both of those listed as "soft-touch" are SPST, one NO, the other NC. I need SPDT.
Thanks anyway.
Quote from: Phoenix on January 27, 2017, 08:15:44 AM
Thanks anyway.
Yeah, I realized a minute ago that I glossed over the "soft touch" requirement.  Oops.
What about a SPST soft touch activating a relay or a CMOS switch or the like?
Phoenix
Quote from: EBK on January 27, 2017, 09:12:30 AM
That's not really appropriate in my application unfortunately: a kinda niche remote footswitch/tap-tempo thing - needing power or any circuitry would negate its utility.
Thanks for the suggestion though!
There may be other options.  From smallbear's product FAQ:
QuoteI'm working in a very quiet environment and need a true-bypass switch that does not have a mechanical "ker-chunk."
I don't have or know of a silent true-bypass stomp switch. That said, there are ways to handle this problem, though none is simple.
This actuator:
http://smallbear-electronics.mybigcommerce.com/switch-actuator-for-b-o-b/ is silent in operation. Combine it with a multi-pole tactile switch: http://smallbear-electronics.mybigcommerce.com/4pdt-latching-pcb-mount/ and you have the equivalent of a silent stomper. But you will have to pay Very careful attention to getting the registration of the parts correct and to securely mounting the switch.
Phoenix
Quote from: EBK on January 27, 2017, 09:24:24 AM
This actuator:
Haha, that's funny, just before you posted this it occurred to me that I could use that part with a double-throw PCB mount switch. The collective consciousness really is real!
I'd rather avoid having to use a PCB for this application, but at least I now have a workable option! Thanks for poking my grey-matter a bit Eric :D
So, if anyone knows where I could get my hands on a momentary soft-touch switch with double-throw, that'd still be greatly appreciated.
Apparently, these guys were able to obtain SPDT soft touch momentary footswitches somewhere.  You might try asking them how they got them: http://www.modestmikesmods.com/silent-step-true-bypass
Edit: Their pic looks suspiciously like SPST....
Another thought occurred to me.  If you find a manufacturer that makes both a NO and NC switch, each version might really be a SPDT in disguise if you feeling like cracking one open.
Govmnt_Lacky
I don't believe anyone makes a momentary Double Pole "soft throw" switch. The only momentary double pole switches I have ever seen were NOT soft throw.
Phoenix
Quote from: EBK on January 27, 2017, 12:40:47 PM
That, or it may be possible to modify standard "clicky" footswitches to be clickless, but who wants to do that if the possibility of an off-the-shelf product exists?
I'm just kinda surprised I haven't been able to find one, it doesn't seem like a particularly unusual part type - I'm certain there'd be almost as much of a market for this type as there is for the SPST-NC and SPST-NO types - in fact it could replace both types...
Quote from: Govmnt_Lacky on January 27, 2017, 01:08:10 PM
Thanks Mr Lacky, but I'm after double THROW, not double pole. I only need a single pole, extra's wouldn't hurt though  ;D
Quote from: Phoenix on January 27, 2017, 10:46:57 PM
but who wants to do that [if] the possibility of an off-the-shelf product exists?
(big "if")
If you don't want to get too creative, you could find out what the minimum lot size and cost would be to get a SPDT momentary soft touch footswitch manufactured.  I'm sure smallbear or others with similar experience would happily share some wisdom on that.
Govmnt_Lacky
I have never seen one. I only know of non-soft touch double throw momentary switches.
Ice-9
I don't think a clickerless soft touch switch with a double throw is available in a momentary version, I am quite likely wrong but I would think the nature of the no/nc throw requires a spring and click to function whether it is momentary or latching. If anyone knows any different then I would also like to know where to get them from.
www.stanleyfx.co.uk
Piece of brass, two screws. Brass touches one screw. Press, it touches the other screw. "Soft", click-free.
Problem is that it WILL go into the in-between state. No-connection at both throws. If "soft", you won't even know it does this. Is this allowed? (Depends utterly on what you are doing.)
If the NC+NC state is not allowed, and a "hard" snap-action is not allowed, then it really comes to a single-throw switch plus a double-throw positive-action slave (relay, JFET, etc).
OK, there is an alternative brass-strip switch. Instead of screws, contacts are more brass strips with significant deflection. Now the in-between state can be *both* throws closed; further motion opens the throw you are leaving. Generally the same "is this allowable?" issues as the other form. And fussier adjustment and more friction.
I just realized today that I actually have the very switch you are looking for:
It actually has two independent SPST switches, one NO and one NC.
Sadly, I can't remember where/when I got it....  :icon_sad:, but hopefully knowledge of the configuration helps refine your search since it is actually DPST.
Phoenix
Quote from: Phoenix on March 01, 2017, 03:04:03 PM
Thanks Eric!
Any manufacturers name on there?
This is all I've got.  Maybe someone will recognize it:
Update: brand is EATON.
