Help me with this transformer connection
Started by Agung Kurniawan, January 31, 2017, 08:48:24 PM
Agung Kurniawan
Hi everyone...
Im planning to build this ps with CT transformer. But I will leave the CT not connected.
Is that anything wrong with the way I wind the transformer and the diode bridge?
Thanks..
Multiple gain stage followed by some active EQ is delicious.
Imagine connecting the two 0V's together.  Look what happens from perspective of the transformer.
Use separate windings for each DC reg.
Agung Kurniawan
Quote from: Rob Strand on January 31, 2017, 09:38:50 PM
is that any bad or destructive affect?
That will NOT work. But a little too hard to explain here.
Why do you have two rectifiers? One rect will feed two 7809 if that is what you want.
Agung Kurniawan
Quote from: PRR on February 01, 2017, 12:44:29 AMWhy do you have two rectifiers? One rect will feed two 7809 if that is what you want.
fairly, I dont know what Im going to do with this circuit :D
the idea is just to get the 'semi-isolated'(sound stupid) output ps.
I have a problem with my fx chain noise.
I thing using 2 of 500mA transformer would be better
Agung Kurniawan
antonis
As long as transformer secondaries are totally seperated (no common wire/joint/point) it's more than fine.. :icon_wink:
