BYOC Green Pony -- to FET or not to FET?
Started by adam193, February 09, 2017, 08:16:34 PM
adam193
Building a green pony: http://byocelectronics.com/greenponyinstructions.pdf
http://buildyourownclone.com/products/green-pony-kit
I have the option to do or not do the FET mod.
Should I? Should I not?
What's the difference between them?
Groovenut
Quote from: adam193 on February 09, 2017, 08:16:34 PM
So the Green Pony is a Maxon OD820 clone with clipping diode and bass shift options. The OD820 is essentially a Tubescreamer with a clean blend built in to the gain pot CCW=clean, CW=gain.
It looks like the FET mod alters the bias point and input frequency of the FET buffer at the input of the circuit. IMO, outside of the very slightly different frequency response, there will be little difference between the two versions. YMMV
Here's a sim capture to illustrate the differences
The altered schem values
You've got to love obsolete technology.....
